Here are 3 quick things to check before your first mow:
1. Antenna Setup
Use the Low Antenna Mount or Flexible Antenna Mount if your yard has shrubs, flowers, trampolines, or other low obstacles. This helps reduce the risk of the antenna being hit, bent, or shifted.
2. Switch to Lawn Tracks
Lawn tracks help protect the lawn surface and are better suited for everyday mowing use.
3. Prepare for Mowing
Check the blades for wear or damage, and apply track grease if needed.
