In an unfinished work plan, "Undock Battery Level" setting allows you to specify the battery percentage at which Yarbo will automatically leave the docking station to continue. You can customize the Undock Battery Level from 50% to 80%.
“Recharge Battery Level ” indicates the minimum battery percentage required for operation. When the battery level falls below this threshold, the Yarbo will automatically return to the docking station for recharging. It can be customized to set the recharge battery level from 15% to 30% .
Yarbo will automatically turn off the auger when the battery level falls below this value to save power. It can be customized to set the Turn off Auger Battery Level from 10% to 15% .
