- Open the Yarbo App and tap Enter My Yard on the home screen.
- Tap the Edit Map icon in the top‑right corner to switch into map‑editing mode.
- Tap the Create button at the bottom of the screen.
- From the list, choose No‑Go Zone.
- In the No‑Go Zone toolbar, tap Template. This opens the customization menu.
- Select Rectangle from the template options.
- A draggable rectangle appears on your map.
- Drag any corner handle to resize, and drag the entire shape to position it exactly where you need the no‑go area.
Switch to Circle in the template menu.
- Use two fingers to pinch‑zoom
- Pinch inward to make the circle smaller.
- Spread outward to enlarge it.
- Drag the circle to its final location on the map.
¶ Switching Between Template Editing and Map Navigation
When you tap and select a No‑Go Zone template, it will be highlighted in red. While highlighted, you can:
- Resize the template: Use a pinch gesture (pinch in to shrink, pinch out to expand).
- Move the template: Drag it to the desired location.
To navigate or zoom the map itself:
- Tap any area outside the template to deselect it (highlight dims).
- You can now pan or zoom the map as usual.
- Combine Shapes: Mix rectangles and circles to match complex obstacles.
- Use Buffering: Make your template slightly larger than the object to account for GPS drift.
- Quick Switching: Remember to deselect the template first if you need to move or resize the map view.
