670 × 570 × 510 mm
(26.4 × 22.4 × 20.1 in)
Full unit: 61 kg(134 lbs)
Module: 3kg(6.6 lbs)
140 × 270 × 320 mm
(5.5 × 10.6 × 12.6 in)
Weight per module port: 3 kg
640 × 910 × 76 mm
(25.2*35.8*3.0 in)
234 × 43 × 488 mm
(9.213 × 1.69 × 19.213 in)
234 × 120 × 1547 mm
(9.213 × 4.724 × 60.906 in)
178 × 152 × 248 mm
(7.0 × 6.0 × 9.8 in)
10 kg (22.5 lbs, without battery cells)
729 × 569 × 742 mm
(29 × 22 × 29 in)
1067 × 729 × 742 mm
(42 × 28 × 29 in)
35 kg (77 lbs)
562 × 370 × 458 mm
(22.1 × 14.6 × 18.0 in)
128 × 69 × 51 cm
(50 × 27 × 20 in)
69 × 74 × 40 cm
(27 × 29 × 15 in)
Full unit: 90 kg (198 lbs)
Module only: 30 kg (66 lbs)
| Component | Dimensions (mm) | Dimensions (in) | Weight |
| Yarbo Core | 670 × 570 × 510 | 26.4 × 22.4 × 20.1 | 61 kg |
| Module Port (Single) | 140 × 270 × 320 | 5.5 × 10.6 × 12.6 | 3 kg |
| Battery Pack | 178 × 152 × 248 | 7.0 × 6.0 × 9.8 | 10 kg (housing only) |
| Docking Station | 640 × 910 × 76 | 25.2 × 35.8 × 3.0 | — |
| Data Center (Main Unit) | 234 × 43 × 488 | 9.213 × 1.69 × 19.213 | — |
| Data Center (Installed w/ Pole) | 234 × 120 × 1547 | 9.213 × 4.724 × 60.906 | — |
| Snow Blower Module (only) | 729 × 569 × 742 | 29 × 22 × 29 | 35 kg |
| Snow Blower + Core | 1067 × 729 × 742 | 42 × 28 × 29 | — |
| Blower Module | 562 × 370 × 458 | 22.1 × 14.6 × 18.0 | — |
| Lawn Mower Module (only) | 690 × 740 × 400 | 27 × 29 × 15 | 30 kg |
| Mower + Core (Full Unit) | 1280 × 690 × 510 | 50 × 27 × 20 | 90 kg |
