- Route calculation takes a long time on large maps.
- Users experience extended waiting times before work plans start.
- The route planning algorithm takes longer to calculate when handling very large maps.
- Map size screenshots showing affected areas.
- Approximate time taken for route calculation.
- App version and rover firmware version.
- Use Spiral Pattern mode for faster calculations on large maps.
- Consider dividing your property into smaller mapped areas for quicker processing.
- Optimizing route planning algorithm to reduce time complexity and avoid timeout bugs.
- Adding an Area Splitting feature in the app to handle large maps more efficiently (upcoming release).
As a temporary workaround, try using Spiral pattern or splitting your map into smaller sections. A long-term software fix and area-splitting feature are already in development.
