If your Yarbo's core unit is flashing rainbow lights and your app shows the machine as offline — even when you can see it on the app's main page — this article walks you through a recovery step that helps Yarbo Support diagnose and remotely fix your unit.
This is not a regular setup process. It's a remedy for a specific situation where:
This process WILL:
This process WILL NOT:
After completing this process, your Yarbo will still appear offline in the app. That's expected. Please contact Yarbo Support afterward so they can take it from there.
| If your Yarbo appears to be offline and isn't connecting to the network normally, you may need to set up its Wi-Fi connection through Bluetooth instead. |
Important: This method only works for Yarbo machines from 2024 or later. If you have a 2023 model, please use the Hotspot mode to configure Wi-Fi instead.
Make sure your Yarbo is already bound to your account in the Yarbo app. If you haven't bound the machine yet, please complete the binding process first.
Binding does not require an internet connection on the machine, so you can do this even when Yarbo is offline.
Once Bluetooth is connected:
Tip: If Bluetooth doesn't connect right away, make sure:
- Bluetooth is turned on in your phone settings
- You're standing close to the Yarbo
- The Yarbo is powered on
Follow the normal Wi-Fi setup flow:
If Bluetooth doesn't connect automatically when you open My Yard, try these steps in order:
If your Yarbo doesn't show up even on the manual scan page, please contact Yarbo Support via support@yarbo.com for further assistance. They can help diagnose whether the issue requires service or replacement.
