If you notice that your Yarbo lawn mower is avoiding areas that are actually safe to mow, you can mark those areas as No-Vision Zones to allow the mower to operate normally.
Yarbo uses advanced image segmentation technology to detect and avoid obstacles. However, in some cases, the camera might misidentify safe areas—such as shadows or certain textures—as obstacles, causing the mower to avoid them unnecessarily. In such cases, a No-Vision Zone can be a helpful solution.
Important: Please ensure that all areas marked as No-Vision Zones are safe, as camera-based obstacle avoidance will be disabled within these zones.
Go to the Edit Map page.
Tap Create, then select No-Vision Zone.
