A pattern that follows an automated spiral route based on the algorithm (so the sequence of whether it starts from outer to the center or from center to the outer may vary), ensuring a smooth and consistent mowing experience.
The Adaptive Route Mode has been introduced to provide more flexible area routing options.
📍 To enable it, go to Area Settings and switch the route pattern to Adaptive Route Mode.
When selected:
The Yarbo Lawn Mower will automatically choose the nearest starting point to begin mowing.
Instead of mowing around each no-go zone perimeter separately, it will mow the perimeter of a no-go zone when it naturally reaches it along the set route.
Reduces unnecessary travel lines that cut across an area.
Minimizes lawn wear by applying adaptive routes that reduce frequent turns in narrow spaces.
