Turn modes are automatically adjusted in specific situations. For example:
Spiral Mode disables U-Turn and enforces Smart Turn.
In tight spaces or when the rear camera detects obstacles, Yarbo will automatically switch to Zero Turn for maneuverability (e.g., when the path is narrower than one Yarbo length).
Deadends – If a turn is required within a deadend, Zero Turn is used.
Sharp Turns – When the required turning angle falls outside the range of 70–110 degrees, Yarbo defaults to Zero Turn as a safety measure.
U-Turn Mode – Has a turning radius of only half the path width, which can resemble a zero-turn effect in tight areas.
