Yarbo doesn’t rely on just one network connection. As network conditions change around your property, it can use different connection options to help stay connected.
📡 HaLow — Primary connection through the Data Center
🏠 Home Wi-Fi — Alternative connection when available
📶 4G — Cellular backup when HaLow and Wi-Fi aren’t available
HaLow → Home Wi-Fi → 4G
Primary → Alternative → Backup
Swipe through the guide to see how each connection works and when Yarbo uses it.
💡 Tip: If you want 4G available as a backup, make sure it’s enabled under Settings → Network.
Click below for more practical Yarbo Tips & Tricks to help you get the most out of your Yarbo:
#Yarbo #YarboAcademy #YarboTips #SmartYard #RoboticMower
