Dear Yarbo Family,
With the upcoming release of Firmware 3.10.0 and App Version 3.16.0, we know many of you are eager to learn more about the exciting new features and improvements. Below is a detailed overview of the key highlights and optimizations included in this update.
We’ve added Dead Reckoning (DR) to help Yarbo keep working when GPS isn’t stable — like under trees, near walls, or along the eaves of your house. With DR on, Yarbo uses its internal sensors (IMU + odometer) to estimate its position, just like Google Maps still shows your car moving when you drive through a tunnel.
On the Diagnosis Page, you’ll now see a Quality Score (0–1) and new GPS colors:
Some users may feel GPS seems “worse.” In fact, we raised the standard —the bad signals are no longer accepted, so Yarbo pauses instead of drifting off-course. DR fills those gaps.
You can adjust this in: App → Yarbo Lab → PPVS → DR Travel Distance Parameters
By default, DR is ON with these values.
Tip: When Yarbo works near sensitive areas like pools or cliffs, keep the travel distance set low. Higher values let Yarbo continue longer without GPS, which can be unsafe in such environments.
Large open lawn with scattered trees: Increase the In-Area Travel Distance → Yarbo keeps mowing smoothly without pausing too often.
Yards with flowerbeds (NGZs) close to the boundary: Lower the Boundary Travel Distance slightly. This way, if the GPS signal fluctuates, Yarbo will pause earlier rather than “taking a few extra steps” in the tight space.
This feature is still in beta. In the beginning, we recommend monitoring Yarbo closely and adjusting the DR settings step by step to find the parameters that work best for your own yard. If you notice that Yarbo consistently goes out of bounds in a certain area and the Quality score stays below 0.5, we recommend avoiding that section for now. To address such cases, we are working on visual navigation, which will gradually improve accuracy in GPS-challenged areas while ensuring safety.
We’ve optimized the notification system to deliver notifications more accurately and on time. You can now view your full notification history by going to the User Center and clicking the bell icon in the top-right corner.
You can now assign function labels (such as Lawn Mower, Snow Blower, Blower, and SAM) when creating or editing areas. Multiple labels can be applied to a single area.
Additionally, you can choose to view the map filtered by specific function labels, or see an overview of all mapped areas at once.
The Adaptive Route Mode has been introduced to provide more flexible area routing options.
To enable it, go to Area Settings and switch the route pattern to Adaptive Route Mode.
When selected:
Two major improvements have been made to the physical controller:
Note: Due to current limitations, if Auto Light Mode is enabled and the mower automatically turns the lights on in low-light conditions, the lights will remain on even if the environment later becomes brighter.
In the pathway settings, you can choose whether to enable vision detection and ultrasonic detection for Mower Pro.
.png)
In the Work Plan → Plan List section, you can now reorder your plans by simply long-pressing and dragging them to your preferred order. Once adjusted, the new order will be saved automatically. When you open any plan, you’ll also see the last work date for better tracking and planning.
When new firmware is available, the Yarbo app will display an update notification. You can then choose from the following options:
In the schedule settings for the lawn mower and snow blower, you can now choose between two return modes:
How to set return modes:
Note: The return mode can also be modified at any time during an active task for added flexibility.
.png)
A dedicated Wiki platform is now accessible directly from the Profile section in the Yarbo app. Through Yarbo Wiki, you can explore a comprehensive library of FAQs, how-to guides, and product information to help you quickly find answers and solutions —— save your time and enhance your experience.
You can set daily No Charge Period in the app (e.g., 17:00–20:00). The minimum interval is 10 minutes, and the feature is disabled by default.
How to Set A No Charge Period?
Note:
If the Yarbo’s battery drops to 10% or below, it will automatically trigger emergency charging, restoring the battery to 30% before stopping.
After the non-charging period ends, the device will automatically resume charging.
If you manually trigger charging during a non-charging period, a pop-up notification will ask for confirmation to proceed.
You can now control the edge-blowing function using a toggle. It is enabled by default for all zones. When turned off, the blower will skip edge-blowing actions.
Note: The toggle cannot be adjusted while a work plan is in progress, paused, or when Yarbo is returning for recharging.
