Note: Each work area must have snow throwing directions set so work plans can be executed.
Open the Yarbo App → go to Edit Map → select Create or tap an existing Work Area to modify it.
- After completing the area, the app will prompt you to set the snow throwing direction.
- Simply slide your finger along the boundary line to select the desired direction for snow throwing.
- Tap Next to confirm your snow throwing direction and save the setting.
- Tap Redraw if you’d like to redefine or adjust the direction before saving.
- Consider Wind Direction:
Choose a direction that minimizes snow blowback and prevents snow from drifting back into cleared paths.
- Avoid Obstacles:
Set the throw direction away from fences, walls, or delicate areas (e.g., flower beds).
- Adjust as Needed:
Each work area can have its own snow throw direction. You can revisit and modify directions anytime in Edit Map → Work Area Settings
