You can now choose how many times Yarbo clears the area around the Docking Station before docking. This prevents snow buildup that may block the charging contacts or obstruct Yarbo’s return path.
| Option | Description | Recommended For |
| 0 Time | Yarbo directly reverses onto the Docking Station without performing any clearing. | Clear or mild weather conditions. |
| 1 Time | Yarbo drives forward onto the Docking Station with the snow blower active, performing one pass to remove snow in front of the Docking Station. | Light snowfall. |
| 2 Times (Default) | Yarbo performs two clearing passes before docking — first forward left, then forward right — ensuring maximum clearance. | Heavy snowfall or continuous snow conditions. |
Tip: Keeping this setting at “2 Times” during winter ensures stable contact with the charging pads and minimizes the risk of snow-related docking issues.
You can also select which direction Yarbo throws snow during Docking Station cleaning — keeping your area neat and avoiding unwanted buildup.
| Option | Direction | Ideal Use |
| ◀️ Left | Throws snow to the left side of the Docking Station | Avoids obstacles or walkways on the right. |
| ⬆️ Front | Throws snow straight ahead | Perfect for open spaces or when both sides are blocked. |
| ▶️ Right | Throws snow to the right side of the Docking Station | Keeps left side clear for walls, fences, or flower beds. |
Note:
The Snow Throw Direction option will only appear when Docking Station Cleaning Times is set to 1 or 2.
If Cleaning Times is set to 0, this option will not be available, since Yarbo will not perform any snow-clearing passes before docking.
