- For thicker snow or if there are missed spots, choose 11.88 inches.
- To improve clearing efficiency, choose 0 inches (though this may result in some missed snow).
- A balanced option would be 5.88 inches (recommended).
- Recommended settings: Quiet or Mild. Both light and heavy snow can be cleared with no speed restrictions.
- Robust and Turbo modes are generally used for clearing wet snow, but they have speed limitations, only usable on Slow or Medium speed.
- For flat surfaces (e.g., concrete, asphalt), set the height to 0 inches.
- For brick surfaces, cracks, or uneven roads, set the height between 0.4 to 0.6 inches.
- For gravel or muddy surfaces, set the height between 0.8 to 1.2 inches.
- For non-snow activities, set the height to High.
- To avoid throwing snow onto neighbors' property, choose an angle between -5 to 5 for both the lowest and highest positions.
- If you find the snow throw distance to be too short, choose an angle between 40 to 50 for both positions.
- To automatically adjust the snow throw distance based on the machine's position, select an angle between -5 to 50 for both the lowest and highest positions. (The farther the machine is from the snow throw area, the farther the snow will be thrown, and vice versa).
