Winter weather can be harsh, especially for those responsible for keeping walkways and driveways clear of snow. One common issue faced by users of snow blower, Yarbo, is the freezing of tracks after extended periods of use. This article will guide you through the steps to prevent this problem, ensuring your yarbo stays operational and efficient throughout the winter season.
After each snow clearing session, it's crucial to perform a proper maintenance routine to prevent the tracks from freezing. The first step is to clean the area between the tracks and the walking motor. This can be done by:
By keeping the tracks and walking motor clear of snow and ice, you reduce the likelihood of the tracks freezing to the track, which can cause operational issues.
Regular lubrication is essential to keep the tracks moving smoothly and to prevent them from freezing. After every four charges, it's recommended to apply lubricating grease to the tracks. For detailed instructions on how to apply lubricating grease, refer to the following resources:
Lubrication not only reduces friction but also creates a barrier that can help prevent ice from forming between the tracks and the walking motor.
If, despite your best efforts, the tracks freeze, there are steps you can take to thaw them out:
By following these simple maintenance tips, you can significantly reduce the risk of your snow blower's tracks freezing during winter operations. Regular cleaning, lubrication, and proper storage can extend the life of your yarbo and ensure it's ready to tackle the next snowfall. Stay proactive with your yarbo's care, and you'll keep your paths clear and safe all winter long.
