First, observe the lights on various parts of the Yarbo to confirm which light is flickering abnormally or not turning on.
¶ Normal Conditions and Fault Diagnosis for Each Light
Lawn Mower Headlight:
- Default state: Off (can be manually turned on by users).
- During work plan: Always on.
Snowblower Headlight:
Battery Level Indicator Light:
Displays battery level:
- 80%-100%: White
- 20%-80%: Yellow
- Below 20%: Red
Internal error:
- Left light off, right light flashing red: Restart Yarbo to resolve.
- During auto plan: Always on.
- Generally uncontrollable and flashes during a work plan.
Docker Not Running:
- If Docker is not running, the tail light may flash from red to blue and then green. A restart may solve this issue.
Recent Updates:
- If there have been recent updates, the tail light may also flash from red to blue and then green. Because the system may be deploying new packages. So please just wait for the deployment to be finished. It may take about half an hour to deploy the new firmware depending on the quality of internet connections.
- Compare the current light status with the normal conditions listed above to determine which specific light is malfunctioning.
For Front Headlights and Central Lights:
- Check for any change in the controller settings if you have accidentally turned off or on the lights.
For Camera Auxiliary Light and Roof Warning Light :
- Verify that the system settings are correct or if your unit is currently in a work plan.
For Rear Tail Light :
- It may be undergoing an update, so please wait for about half an hour. If the light does not turn back to normal, a restart could be helpful.
By following the steps outlined above, you should be able to effectively identify and resolve issues with your Yarbo lights. If the problem persists, please contact technical support for further assistance.
We hope this guide is helpful to you! If you have any questions, feel free to reach out to us at any time.
