| If your Yarbo appears to be offline and isn't connecting to the network normally, you may need to set up its Wi-Fi connection through Bluetooth instead. This guide walks you through the process step by step. |
Important: This method only works for Yarbo machines from 2024 or later. If you have a 2023 model, please use the Hotspot mode to configure Wi-Fi instead.
Make sure your Yarbo is already bound to your account in the Yarbo app. If you haven't bound the machine yet, please complete the binding process first.
Binding does not require an internet connection on the machine, so you can do this even when Yarbo is offline.
Once Bluetooth is connected:
Tip: If Bluetooth doesn't connect right away, make sure:
- Bluetooth is turned on in your phone settings
- You're standing close to the Yarbo
- The Yarbo is powered on
Follow the normal Wi-Fi setup flow:
Once connected, your Yarbo should come back online in the app.
If Bluetooth doesn't connect automatically when you open My Yard, try these steps in order:
If your Yarbo doesn't show up even on the manual scan page, please contact Yarbo Support via support@yarbo.com for further assistance. They can help diagnose whether the issue requires service or replacement.
