The default mowing pattern. Yarbo follows straight, parallel lines for a clean and efficient result.
Parallel supports both Route Angle and Route Rotation Degree, allowing you to adjust the mowing direction and automatically rotate the path between work plans.
Yarbo automatically selects the nearest starting point, reduces unnecessary travel lines, handles no-go zones along the route, and plans separate paths for complex sections when needed.
