This is normal behavior. Even when Yarbo isn’t actively working, certain systems (like RTK, HaLow, the operating system, anti-theft system, and core electronics) remain active in the background, which causes gradual power draw.
When the app shows 100% but the actual charge is just above 90%, Yarbo enters trickle charging mode. This helps optimize battery health while minimizing power usage.
Result:
You might see the app still display “charging” even though the battery is not topped off to exactly 100%.
Charging power now adjusts dynamically based on battery temperature.
If charging is paused due to overheating, it will now automatically resume once the battery has cooled.
Turnarounds
Yes! You can remove the battery and charge it directly.
How:
✔️ Use the official Wired Charger 👉 Buy here
If you notice:
Please reach out via support@yarbo.com so our team can investigate and assist.
For more details on long-term storage and battery care, check out:
🔗 Battery Maintenance
