- Open the Yarbo App and go to Add Device.
- Follow the on-screen instructions to connect your new Yarbo Core via Bluetooth.
Your Yarbo needs to be online for us to migrate your map.
- If you receive a new Core but plan to keep using your old DC, you can skip DC replacement. Simply restore your maps from the cloud, and your system will continue to work.
- If you receive a new DC (or decide to relocate your existing DC), you must go through the DC initialization process to ensure it’s correctly installed and aligned. After initialization, restore your maps from the cloud and then run Correct Map Drift to realign map position with the new DC.
- Only when the DC are replaced separately, and you need them to work together while not changing DC location, should you follow the pairing process here:
🔗 Replace Data Center
- With the new cloud service, your Yarbo map data is now automatically backed up:
- The latest map adjustments from your Yarbo are securely uploaded to the cloud.
- Each unit keeps one cloud map version at any given time.
- You can view and recover maps directly from the app by selecting the corresponding Serial Number (SN).
Cloud Backup & Map Recovery
- Only the Yarbo owner’s app account can back up and recover maps. Shared user accounts cannot perform this action.
