We’ve introduced a new Auto Shutdown at Low Battery feature to help protect the battery and ensure safer operation. How it works:
Additional details:
We’ve added a new Safety Buffer option to the Plow Blade settings, giving you more control over how closely Yarbo clears along boundaries.
What it does:
How it works:
Additional details:
You can now choose which work plan runs when automatic scheduling is enabled. Instead of relying on a default plan, you can select a specific plan in advance. When a weather-triggered schedule is activated, Yarbo will follow the selected plan automatically. This gives you more control over how Yarbo operates in different weather conditions, ensuring the right strategy is applied every time. |
| You can now split mapped areas directly in the app. After splitting, you can choose to keep specific sections or retain all resulting areas based on your needs. |
| Double-tap any camera view (front, rear, or side) to expand it to full screen, helping you monitor more precisely and stay aware of your surroundings—especially in complex environments. |
Yarbo now supports both Data Center and NetRTK Service for positioning. To switch between them, go to: Yarbo Settings → Positioning Services
NetRTK service is free for the first 3 months.
In Area Settings, you can now enable Path Offset to reduce turf damage caused by repeatedly using the same route within an area. This feature is available when using Parallel, Spiral, or Adaptive route patterns. |
We’ve added a new Offset option to Work Twice for the Snow Blower to improve overall snow clearing performance.
When enabled, Yarbo slightly shifts the path during the second pass, helping clear snow left between paths and delivering more consistent coverage—without repeatedly running over the same tracks.
The feature is off by default and can be enabled in Area Settings when using Work Twice.
Note: This feature is not supported in slope patterns.
We’ve introduced new Thin Snow and Heavy Snow cleaning modes to better handle different snow conditions and improve overall efficiency.
These options are available under Area Settings → Cleaning Mode, giving you more control based on real-world conditions.
Work plans now display the labels assigned to their included areas, making it easier to identify and manage different plans at a glance.
